Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-07-2004, 02:46 AM
94rangerprerunner 94rangerprerunner is offline
Garage is empty, add now
94rangerprerunner is starting off with a positive reputation.
Leaking Rad. fluid between engine and trans.! Please help!
I have a 94 2.3l, I just finshed putting my rebuilt engine back in it, it runs perfect. Now it leaking radiator fluid down the back of the engine somewhere, it starts dripping from where the engine and transmission bolt together. Does anybody got any ideas on where the fluid could be leaking from, the fluids perfectly green almost. Thanks for the help in adavance.
__________________
94' ranger 4.0 v6
-Soon to race class7
  #2 (permalink)
Old 02-07-2004, 10:43 AM
tomw tomw is offline
1985 Ford Ranger
tomw has a good reputation on FTE.tomw has a good reputation on FTE.
You may have a small diameter hose that routes around the backside of the head to the bottom of the intake manifold. It is less than 1/2" in diameter, and connects to a 'T' fitting on a heater hose. That may be the leak, or you may have a head gasket leak, or an intake manifold gasket leak. Look at the sides of the block, and at the back side of the cylinder head. Try doing this before the engine gets so hot that the coolant will evaporate from the hot surfaces. Loose hoses are a lot easier to fix...
good luck
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #3 (permalink)
Old 02-07-2004, 11:37 AM
There aren't really any hoses crossingover the backside of the engine. They said on another forum the freeze plug, is this possible?
__________________
94' ranger 4.0 v6
  #4 (permalink)
Old 02-09-2004, 07:12 AM
1985 Ford Ranger
Certainly possible. When you did the block, did you inspect the freeze plugs? If they showed any sign of corrosion, they were on their way out. Any sign of rusticles or dripping, bad news.
You may be able to get a dentist style mirror to look at the back of the head. If it is in the head, you'll be best off by removing the head for repair. If it is a freezeplug behind the clutch plate or flywheel, you'll have to drop the trans to get at it.
tom
__________________
  #5 (permalink)
Old 02-09-2004, 07:49 PM
Ah, this sucks! Wouldn't they have probably changed the freeze plugs out when they did the rebuild on my engine?
__________________
94' ranger 4.0 v6
  #6 (permalink)
Old 02-20-2004, 12:30 AM
I found out that one of the ones on the side is leaking, possibly the other one's to, I just need to take a closer look. Is there away to seal them off with out having to take the engine out or the head? Can you just put some sort of sealer around the freeze plugs? Thanks
__________________
94' ranger 4.0 v6
  #7 (permalink)
Old 02-20-2004, 10:52 AM
1985 Ford Ranger
You can buy replacement freeze plugs made of some rubber type compound, with a flat washer and a bolt/nut. Use a cold chisel (screwdriver) to poke a hole in the old leaky one, and pry it out. Clean the hole as best you can, and push in the rubber one, tighten the nut. The rubber ones are just easy to put in, as you don't have to try to pound on something hidden behind a manifold or whatever.
tom
__________________
  #8 (permalink)
Old 02-24-2004, 11:18 PM
Thanks alot, I will have to do that.
__________________
94' ranger 4.0 v6
Tags
02, 03, 1999, engine, f350, fluid, ford, harley, leaking, leaks, motor, oil, ranger, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
