rearend rebuild instructions?
Old 02-03-2004, 08:26 PM
stangman67's Avatar
stangman67
stangman67 is offline
I need directions on rebuilding a ford 8". I have a 2.80 rear and im stepping up to 4.11 and wanted to do it myself. Maybe its similar to the 9"? thanks
Old 02-03-2004, 10:46 PM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
Do you mean the 8.8"? If so you can get a rebuilding video from a user "badshoe" on ebay. He might not have one being sold right now, but e-mail him and he can put one up for you. Very good video and it's how I learned.
Old 02-04-2004, 11:56 AM
DMW's Avatar
DMW
DMW is offline
Richmond Gear in Liberty, SC, has a ring & pinion install video that covers the 8.8". It's pretty good, but it assumes you know how to press off bearings, work a dial indicator, etc.
Old 02-04-2004, 12:06 PM
Boss_358's Avatar
Boss_358
Boss_358 is offline
Before jumping to conclusions we need to know what the axle is in. It could be an 8" he is asking about. If so, Yes, it is similar to the 9". You might be able to go off of the same directions as a 9.
Old 02-04-2004, 02:23 PM
loudfords's Avatar
loudfords
loudfords is offline
There is an FTE tech article quite a ways down about rebuilding a 9", which should be similar to your 8". Is this 8" in the Stang listed in your signature?
Old 02-04-2004, 04:23 PM
stangman67's Avatar
stangman67
Yes it is the 8" in the mustang. I have 3.55 and a posi for the street, and i just wanted to find some info for a gear swap in another housing with a mini spool. I have been told that even though my car makes a good amount of power, since it has low torque, i should give the 8" a chance. Not sure about the old axles though. Thanks for the help, ill check out that article.
jondawg
10-24-2007 09:52 PM
bigbadwolfe
06-23-2007 05:42 AM
elemint
03-29-2004 08:45 PM
jml
12-30-2002 06:53 AM
Forddrof
08-11-2002 07:52 AM
Quick Reply: rearend rebuild instructions?
