1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Buying used super-duty....questions
Old 01-21-2004, 08:15 PM
timmo484's Avatar
timmo484
timmo484 is offline
This is my first post, and as best I can tell this is where it belongs. I currently own a 93 F-150 XL, but I'm shopping for a new truck. At any rate, I am checking out a '93 F-250, Standard Diesel, 4X4, Extended Cab, Long Bed this weekend that I will most likely purchase. I plan on running it by my mechanic before I purchase it, but I was wondering if there are any inherent defects or typical red flags I could be on the lookout for. I am looking for a work truck/daily driver and this seems like a pretty dependable truck but I want to make sure I'm not stuck with a lemon as it is my first Heavy-Duty Truck.
Old 01-21-2004, 09:51 PM
69oiler's Avatar
69oiler
69oiler is offline
ask if the owner used the proper coolant additive. block cavitation is the biggest killer of the thin-cylinder-walled 7.3 IDI. you can get test strips to test the coolant at a Ford or International dealer. NAPA might have them too.
if the coolant was not maintained properly, you may want to pass on this one.
check out www.ford-trucks.com for great forums on Ford diesel pickups. search the 7.3 IDI forum for "cavitation"
btw, a '93 is not a Super Duty. SD's came out for the '99 model year in '98.
good luck
ROB
Old 01-21-2004, 10:02 PM
probablecause's Avatar
probablecause
probablecause is offline
Give me the VIN and I'll run it on Carfax.com
Old 01-22-2004, 10:10 AM
timmo484's Avatar
timmo484
timmo484 is offline
69oiler - thanks for clearing that up about the super duty - I'll check on those strips.
paul407 - I'll get that VIN to you asap - thanks!
Old 01-22-2004, 11:33 AM
HDMustF250's Avatar
HDMustF250
HDMustF250 is offline
Also, get an oil sample frome the engine and send it out. Cost about $20, but it will tell you the health of the engine, how the guy ran oil, and whether or not there is any coolant in there. If there are fragments or coolant pass big time.
Old 01-27-2004, 04:01 PM
probablecause
Question
Where do you send the oil to?
Thanks
Paul
RKRider
New Member Introductions
03-31-2016 10:37 PM
lvracin
03-31-2013 05:45 PM
0m3g4
09-22-2011 10:33 PM
Maco350
06-03-2011 04:39 AM
mustanginca
07-18-2006 10:44 PM
Quick Reply: Buying used super-duty....questions
