5.4 liter egr valve flow problem
Old 01-14-2004, 08:24 PM
pageparsley's Avatar
pageparsley
pageparsley is offline
i have a 97 ford expedition with a 5.4 liter with 108k miles. my check engine light has been coming on every once in a while and when i check it with my obd 2 it reads either insufficient or excessive egr valve flow. do i need to replace it or can i take it out and clean it to reuse. could the problemm be with any thing else. when the light comes on my engine seems to be very lightly chugging when cruising at a moderate speed. thanks for any help anyone has.
Old 01-15-2004, 08:01 AM
furrby's Avatar
furrby
furrby is offline
i had the same problem. mine was the sensor that reads the egr. but in my reseach for mine i found that i can be cleaned. i can't remember what to use but i got my information from the dealership. but the sensor is a common problem. when i had mine replaced at the dealer with 35k miles on my truck the service man told me the sensor for my truck has a 50k warranty because of the problems they have had. hope this will help.
furrby
Old 01-15-2004, 08:29 AM
FortyFords's Avatar
FortyFords
FortyFords is offline
Sometimes its the sensor, sometimes its the hoses or the ports the hoses hook to ,they become clogged with carbon build up.
Try cleaning the hose ports first.
It can also be the EGRV solenoid or the EGR itself
Just some more thoughts on the subject
Rich
Old 01-15-2004, 08:59 AM
turbo TED's Avatar
turbo TED
turbo TED is offline
pageparsley: The two parts that may the culprit & I would be willing to bet real money that it is one of these two parts if not both, the delta pressure feedback sensor [dpfe] sensor ford part
# is f63z9j459aa, and the sensor relay is ford part # f77z9j460ab
both of these parts work in sync to provide correct egr flow &
smooth vehicle operation, the dpfe sensor will not cause noticeable operation problems you should just get a check engine light, now on the the hand if the relay is the culprit you will probaly notice some vehicle surging at around 40mph up to 55mph this could be described as a backwards to forewards
motion of the vehicle. From experience if the relay is at fault it
would be wise to replace both sensor & relay[ I mean its like you
would not change your oil without changeing your oil filter] , if it is just the sensor you have a good chance that may be all you need replace. If you run into any problems tell us.
turbo ted
Old 07-13-2008, 09:53 AM
DEAN54's Avatar
DEAN54
DEAN54 is offline
Hello, I have the problem of same problem with the DPFE sensor. My question is where is it located. 1997, F-150 I have looked and can not find it. Can any one direct to its location in the engin compartment.
Old 07-13-2008, 09:56 AM
DEAN54's Avatar
DEAN54
DEAN54 is offline
Can not find the old DPFE Sensor
Where is this senor normally locatedon a 1997 F150, 5.4 liter.
Old 07-13-2008, 02:02 PM
DaviMac424's Avatar
DaviMac424
DaviMac424 is offline
I too have had to replace the DPFE sensor in my '97 E350 5.4L. It was located on the drivers side of the engine, almost all the way to the back, on the intake maniford (just forward of the EGR valve itself.
davenpt
2004 - 2008 F150
21
07-07-2014 01:33 PM
dtudor
2004 - 2008 F150
10-26-2008 05:50 PM
shmitee
Modular V8 (4.6L, 5.4L)
03-04-2006 07:32 PM
RGrimes
1997 - 2003 F150
02-07-2006 12:36 PM
miichael
17
12-17-2005 10:27 AM
Quick Reply: 5.4 liter egr valve flow problem
