Starter solenoid
Starter selonoid
I have put a link to a drawing i made of my starter relay. I was wondering if anyone can tell me what each of the wires are for by the description i have of them. Also i was wondering where i should run an accessory line for my tach , cigarette lighter, and radio to on this relay. thank you
http://f2.pg.photos.yahoo.com/ph/gla...arterrelay.jpg
i have lots of accesories on my truck alraeday and i am going to buy a 2nd fuse box for all of my accessorries this week and install it.. i dont know alot about vehicles, but i am learning.. how would a 2nd fuse box be hooked up.. i keep blowing fuses in the box i have. The previous owner.. my genious cousin.. hooked up an electric fuel pump, kc lights, an oil pressure guage and a few things i have removed before i had the truck, so it was a wiring mess and i am trying to sort out some of it and have the accessories and the necessities on separate boxes...any suggestions?
run a seperate fuse box with a six gauge wire direct from the positive of the battery. all items hooked to it will have to have there own off switch otherwise they will be powered at all times.
you can also install a toggle switch on that 6 ga feed line to shut off all the power to the fuse box
i think the starter relay has an accy. power and a constant power outlet on it, but i dont know which is which. if i can find out which one is the accy out let i think i could just connect it there and not have to have a switch.. i think that is why my bat. is draining right now, because i have it hooked straight to the battery, do you know where i could find out the info i am looking for?
well as i stated in my second post your link is not working.
there should be no power at either one of the 2 small terminals on the solenoid when the key is in the off position. there is a fusible link wire that hooks up to the same side as your POS cable from the battery that the fuse box gets it's power from to run the small ACC's such as the cig. lighter, clock radio or other stuff that you don't need the key on for
Ok. sorry about the lnkk...does the fusable link wire supply the whole fuse box with power, or just the accessories? Also, would there be a difference if i ran a connection to the positive of the bat , or the side of the selonoid that the pos. connected to? And do you know of any way i could hook the @nd fuse box up to where it would come on with the key in the accy. and start posistion.. the toggle switch is a good idea, just wondering if there is any other way without a switch...thanks for your help so far by the way..
no it will not matter if you run it to the solenoid or the battery.
take a test light , start the truck and check your small connection stud's on the solenoid to see which one is energized when the truck is running, use that one to run your second wire for your fuse box and you will be fine. power will shut off to that 2nd fuse box when you turn off the key
Ok. thank you for your help.this should help me manage my accessories better and stop blowing fuses.. finally i will be able to straighten up some of the wiring mess i found in it..Im just trying to get it all planned out how i want it before i start doing my body and chassis work to it.. i just looked at your truck and that is mostly like what i have planned for mine, except for i am planning on keeping the 400 in it. thatks again for your help
back you said something about the battery draining?? one way to test this for a short is to disconect the POS cable from the battery, hook up a 12 volt test light between the battery and the POS cable, if the test light light's up then you have a short in your system somewhere. to track this short down start pulling fuses one at atime and watch and see if the light goes out, if it goes out you have found your circuit with a short. all this is done with the key in the off position.
good luck
good luck
