a small block or a big block?
shane74
If your search funtion doesn't currently work for you, as it doesn't for myself. Most books or performance related literature, will classify the 351/400/modifieds under "335 series small block". ONly difference between the windsor and the modified, is the modified weighs a lot more and uses a big block bellhousing. Later
The 351C has a small-block bellhousing.
The 351M/400 shares a bellhousing and distributor with the 429/460 big-blocks
All of the 351's were considered small-blocks, along with the 400
The 330, 332, 352, 360, 361, 390, 391, 406, 410, 427, 428 are sometimes referred to as big-block motors which they are but, they are really FE Block motors whick is another debated subject of what FE stands for. They do not have the same bellhousing as the 429/460 big blocks.
The 370, 429, 460's are considered the big-blocks.
