Checking King Pins
Old 01-12-2004, 01:44 AM
Scrapiron66's Avatar
Scrapiron66
Scrapiron66 is offline
Checking King Pins
How do I check the condition of my king pins on my 72 F100? Is it the same procedure as for checking ball joints?
Old 01-12-2004, 11:16 AM
rebocardo's Avatar
rebocardo
rebocardo is offline
1972 F-100 4x4?
Yes, jack the front end up so both wheels are off the ground and try pulling the top/bottom of the tire in and out. Usually the bottom kingpin goes first and your tires will look like this /\
Old 01-12-2004, 11:53 AM
user 5363849's Avatar
user 5363849
user 5363849 is offline
It helps to actually peek around the tire and look at where the I-beam goes into the knuckle. You will see any play as relative movement between the parts.
Also, make sure that your thrust bearing don't look all torn up.
Old 01-12-2004, 12:40 PM
rainbowATF's Avatar
rainbowATF
rainbowATF is offline
Kingpin
Your truck looks like 4x2. RWD only on your 1972 F100. The 76 is the 4x4. If so then your kingpin will be a single pin on each side. Kits include kingpins; bushings for spindle, a bearing for under axle, and maybe some shims. Kits available with either nylon or metal bushings. Many threads about this on various forums.
72CC428
23
11-26-2017 08:49 AM
fisherman_chuck
06-02-2016 09:39 PM
MADFord4X4
22
07-16-2010 12:58 AM
flcobra
16
10-01-2008 09:20 PM
zsir
01-07-2003 11:45 AM
Quick Reply: Checking King Pins
