Crankshaft Position Sensor
Is there a method to check the crankshaft position sensor?. My 82 Bronco 351W just quit at about 60mph as if you would have shot it. It did not run rough or anything, just shut down. I had the ignition box tested and it is fine, the coil is getting power and has checked OK also. So now I am down to the cps or the EEC box. Oh yea no spark to the plugs either.
Thanks for any help....
on
It sounds like the Crankshaft Position Sensor. You can test it with a multi-meter. Test the pins on the gray and dark blue wires. The spec is 100-640 ohm's. If it tests 'open circuit', the CPS is bad and needs to be replaced.
When you replace the CPS, rotate the crankshaft so that the tip of one of the four lobes on the pulse ring lines up with the tip of the CPS. Gap the opening between the two at .075". Then tighten the clamp.
All 302/351w engines with EEC-III have a CPS and do not use a magnetic coil pickup in the distributor.
Thanks for joining us at FTE!
Many thanks.
It did exactly what you are describing
82fordguy
17
08-14-2016 09:27 PM
guntherh_3
1997-2006 Expedition & Navigator
03-11-2016 01:10 PM
