serpentine belt shredding
It will be very hard to give you an answer with the limited info you have given us. What is shredding? The sides, the groves, the backing? Is it squealing.
I know in my neck of the woods the cold will crack the v groves in about a week sometimes but I don't replace them for a long while. Only until the cracks get into the cords.
Off hand I'd have to say something is out of allingment. Some pulley isn't set right and is tearing it up.
Oh yeah, welcome to FTE.
Hello OO
I'd have to agree with cr250 on the alignment problem. Have you had anything changed out b4 the belt shredding started (ie alternator/ac/water pump etc.?). If not you might also have a bearing thats starting to sieze up on any of those and also the idler pully or tensioner pully. If you can you might want to pull the belt off and hand check each pully by spinning them and push/pulling on them by hand to make sure there arent any issues with them. Just my 2cp. Hope this helps
Sam
00 expy 5.4L
97F350 psd
89 Elite 28' MH 460
Sam
00 expy 5.4L
97F350 psd
89 Elite 28' MH 460
I changed my water pump recently and after installation my belt began to shread for no seeming reason......... came to find out that the upper radiator hose clamp going into the water pump was positioned in such a way that it was making contact with the belt............ simply repositioned the clamp, problem solved.
skierbri10
02-15-2010 10:13 PM
44magnum
19
01-05-2007 08:30 AM
MJBEASL1978
06-05-2006 02:41 PM
