Which Y-Block is the most Popular here
Most parts are interchangable among the Y-blocks. The 312 will have the most power - there is no replacement for displacement. The 292 blocks bored out to 312 and a 312 crank turned to fit are the best way to go because they offer a little more support at the mains. For a lot of information about parts go to "www.ford-y-block.com." Also check out "www.y-blocksforever.com." Most aftermarket parts will fit most Y-blocks.
Yes that is what I am thinking of doing. Driving the truck while rebuilding a 292. From what I hear that is the only way to go and then boring the cylinders to make them a 312 and using a 312 crank. I am also looking into the 4 b carb manifold that seems to be everywhere. The idea of dealing with multiple carbs is not a good idea. You guys articles are helping me a bunch. I was leaning toward the 292 already and that article did it. One other thing, did they ever install a AC on Power Steering pump on any of these 292's. I would like to go that route to add pw steering or an AC. I do not like the idea of fabing crap to put on a motor.
When I was a kid my Dad had a 1964 Ford F250 with 292, factory power steering, and an add on AC made by Mark IV. It was the custom cab with zippered pockets in the doors. It had a great sounding dual exhaust. The little 292 had a lot of gusto on the takeout. The only thing it needed was one of those add on dual ranges that you put in the driveline behind the tranny, since it ran about 2,800 RPM at 60 mph. It still rates as my all time favorite pickup. They certainly don't make them like that any more.
Originally Posted by Fordication
Ok I was wondering which Y-Block has the most power and availability for aftermarket add-ons. I was wonderng about the 312 in particular but I am still learning so you tell me.
Myself, i think the most dependable Yblock was the 1954 239, but yes parts are scarce for those. I also think the 272 Yblock is a better engine. 292 Yblocks are more easily attained and can be machined to be wonderfull engines, and if you can get a truck 292 yblock "cite", that baby has a steel crankshaft in it. The 292 is a good and available engine and has plenty of power, just beware of those rear oil seals, and it's the best one.....Janet
EDIT: Forgot to add, you really do not want a 312 yblock, reason why, is because they had unrepairable cracks where the mains bolted on in most of them, and a 292 has just about as much power anyway
Dang Janet. I forgot I started this thread. I never had a 239 but at the time I did not know it. My truck came with a 272 and I have refreshed it. I am rebuilding a 292 for bad *** performance and so far I am finding parts real easy and affordable. I cannot wait to see what kind of power I get to that rear end. Ed
Janets Yblocks
I forgot to mention it, but i did two other non stock alterations on both my Yblock vehicles, next to the frame in front of the fuel filter, which is a big metal filter, i added that 100 dollar Holley electric fuel pump on both of mine, you just turn on the key and you hear it lightly buzzz a few secons, pump the accelerator one time, and bongo, starts right up, even in the winter i don't have to use a chocke on my carb....janet
Last edited by Janet40; 07-14-2004 at 06:36 PM. Reason: Another non stock thing i did on mine
Yep mine came with an electric fuel pump. I was going to replace it with a new mechanical but now I do not know. Ed
PS. Make sure your fuel filter is located behind the electric fuel pump, and also don't have one up by the engine, put an electric pump under your cab, that way it runs cooler and last longer. Your best one is that 100 to 110 dollar Holley electric pump, it's well worth the investment, then carry a 30 dollar cheapo as a spare with you....Janet
Originally Posted by scroob
Someone I know burned his truck to the ground because of an electric fuel pump. The float in the carb stuck and that pump flooded the engine compartment with gas before he could shut it down. Thanks, I'll stick to mechanical, since when the motor stalls it stops pumping.
