1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
New RIMS:16" or 16.5"
Old 09-16-2002, 04:33 AM
Hedgehog's Avatar
Hedgehog
Hedgehog is offline
I plan on putting a 33" tire or equivalent on my 2002 F250 CC. What are the advantages and disadvantages between 16" rims and 16.5" rims?
Old 09-16-2002, 07:47 AM
odinmurphy's Avatar
odinmurphy
odinmurphy is offline
I have 35" tires on 16.5 rims on my my 2000 CC. I am going to go down to 33" because I am tired of rubbing. I thought of going back to a 16" wheel, but in a couple of different wheel and tire combinations I looked at, 16" combos were actually more expensive.
Good Luck.
Murph
Old 09-16-2002, 07:50 AM
79CEEJAY's Avatar
79CEEJAY
79CEEJAY is offline
[updated:LAST EDITED ON 16-Sep-02 AT 09:02 AM (EST)]The 16.5" rim has a tapered seat and the 16" had a bead lock. The 16.5" will tend to throw the tire off the seat when the pressures get too low, where the 16" will not. Also, the 16.5" will become extinct very soon, with even limited bolt patterns available now, so I would go with the 16". Also, in my experience, the 16.5" wheel/tire does not hold balance very well.
The equivalent size to a 33x12.50 in a 16" is a 305/70/16
Old 09-16-2002, 11:22 AM
warmdye's Avatar
warmdye
warmdye is offline
go with the regular 16, these 16.5 don't balance worth crap.
Old 09-16-2002, 11:43 AM
hobert's Avatar
hobert
hobert is offline
I wish I would have went with the 16.5 just because there are alot more tire sizes available. as for it becoming extinct I highly doubt it, look at the sizes out there and how many people run them in the 4x4 market.
Old 09-16-2002, 03:07 PM
spartamouse1's Avatar
spartamouse1
spartamouse1 is offline
the last year for used a 16.5 was 1985. it might be awhile but the writing is on he wall for discontinueing.
Old 09-16-2002, 04:05 PM
chadrock's Avatar
chadrock
chadrock is offline
[updated:LAST EDITED ON 16-Sep-02 AT 05:08 PM (EST)]The main concern that people have between the 16.5" and 16" rims is the issue of the tire coming off the bead with the 16.5" rim (as an above post mentioned). This will only happen if you are airing down the tire to a very low amount, which most people do not. Usually the serrious rock crawlers will air down to an amount where the tire may come off the bead. I have had 16.5" rims on the last two vehicles that I've owned and know may people who have them as well. I have never had a problem with them not balancing well. There are alot more options in tire sizes with the 16.5" rims, but if you are going to stay with a 33" tire size or even a 35", the 16" rim will be fine. Another post above mentioned the cost issue. A 16" tire/rim combo will cost more than a 16.5" tire/rim combo due to the 16" tire being more. For example:
BFG 33x12.50x16.5 $159
BFG 305/70/16 (33x12.50 equiv.) $200
Weld SS 16.5x9.75 $246
Weld SS 16x10 $237
16.5" rim/tire combo $1,620
16" rim/tire combo $1,748
So, the 16.5" is $128 cheaper and the tires (when you need new ones) will be cheaper as well. Personally, I don't think that the 16.5" rim/tires will become extinct any time soon. Hope this helps.
Old 09-16-2002, 05:51 PM
P Eames's Avatar
P Eames
P Eames is offline
Old 01-20-2019, 03:26 PM
R66CRSR's Avatar
R66CRSR
R66CRSR is offline
Wow when this post was started I put new 9.5 X 16.5’s are my then new to me F250 Camper Special. Now it seems that size is almost extinct just found Firestone’s and that was my only choice to replace those original set I put on the truck.
Did find this site if you want to match the outer tire dia. to a different rim dia. sized tire.
https://tiresize.com/tiresizes/9.5R16.5.htm
Old 01-20-2019, 05:01 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
This might be oldest thread I have seen ressurected... 16 years... And you are honestly surprised 16.5" tires are hard to find? It is a dead tire size...
Old 01-20-2019, 05:52 PM
Mike189677's Avatar
Mike189677
Mike189677 is offline
not as hard as you’d think I’ve got a set I’d love to get rid of haha.
Old 01-20-2019, 06:12 PM
Sir Kayakalot's Avatar
Sir Kayakalot
Sir Kayakalot is online now
16 year old thread resurrection?!?! That’s 128 years in internet years
lt dan
01-25-2019 01:08 PM
AlbraiNYa
WTB - Parts & other
09-10-2015 07:26 PM
fordboy_52
General Automotive Discussion
12-03-2009 11:15 PM
lt dan
05-25-2001 12:43 PM
loudfords
03-01-2001 07:52 PM
Quick Reply: New RIMS:16" or 16.5"
