overload spring
overload spring
Does anyone have a suggestion for increasing the load being absorbed by the overload springs on the 2001 f350. When loaded with a 2800lb camper the overload springs barely touch the rubber bumper pads on the frame. I would like a stiffer ride when the camper is loaded and it seems that this could be accomplished by installing a thicker rubber pad on the frame or adding a spacer block to the ends of the overloads to increase the load absorbed by the overload leafs. Does anyone know whether this has been tried or if the necessary parts are available?
My friend with an identical unit has installed Timbren rubber springs but this has lifted the rear end so much that the overload springs no longer become engaged at all and become ,in effect, superfluous.
overload spring
>get a set of air bags by airlift they work wonders
My thoughts exactly!!!
Justin
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=9313&.jpg
http://66.179.41.42/gen1/build/realgeneral.jpg
2002 F-350 SC LB 4X4 6SPD PSD. 3.73 gears. 2.5" leviling kit. K&N air filter. Rhino lined Bed. Prodigy trailer brake controler. 35x12.5x16.5 BFG A/T. 16.5x10 ultra wheels. pop up gooseneck hitch and firestone airbag spring helpers. Reese fifth wheel hitch for my new toy hauler
Justin
overload spring
I have the Firestone airbags on my truck to help level it after loading my camper. I've still wanted to do what you are trying to do just for backup safety sake. My airbags would bottom out if the air was removed before the overload would carry enought weight. Someone had suggested replacing the upper stop rubber with hockey pucks. This sounds like it would work, but I haven't had time to try it out. By drilling holes in the puck so that the bolt head was recessed, the puck would become your overload contact point. You could even add more than one puck for quicker overload contact. I'll report back if I have time to try it; you do the same please.
Harald
2000 F350 4x4 CC DRW V10 4.30ls Lariat LWB.
Firestone Ride-rite airbags, Rancho RS9000 shocks and Torklift Superhitch.
1998 Alpenlite Pendelton 11'10" camper held on by Torklift tie downs.
Remove I_HATE_SPAM_ from email address to email me.
Harald
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
01-22-2015 12:15 PM
Crewcab Turbo
02-03-2012 02:01 PM
