Moisture Problem
Dealership stumped! Moisture problem, please help!
I have a 2000 F150 XL with the 4.6L Triton V-8 engine. I am having a problem with moisture. Everytime it rains or I wash the car it won't run. It starts everytime, but will not run. At first I did not make the connection with the moisture thing and I took it to the dealership and they said it was the fuel pump and replaced it. It kept happening so I took it back again and they said it was the master air flow sensor and replaced that. Still kept happening so I took it to an independet mechanic and he could not find anything wrong. Not until I made the connection did it start to make sense. Everytime this happened I would have it towed to the dealer but by the time it got there it had already dried out and therefore they could not find anything and it would run fine. So I don't know what to do. Any clues? Any ideas on what is getting wet and causing this? Like I said, it starts everytime and will idle momentarily, but then stalls. It even happens as I am driving and has happened in the middle of intersections and busy streets. Very annoying!!! Please help!!!
Hey, good idea. Tonight I went out and turned the truck on and let the hose run over the winshield. After about 2 minutes it died on me as usual. Right after I looked under the dash but did not see any water. However, I am convinced that it is seeping in through the winshield somwhere. Tomorrow morning I am going to a mechanic to reproduce the problem for him and see if he can find anything. I will let you know. Any ballpark figure on how much it cost to reseal the winshield and where I would do something like that?
Well, I have checked for moisture under the dash after spraying the car with water and had a mechanic neighbor come over this morning to help out, we found nothing. We opened the hood and sprayed the engine lightly and got the car to die. He could not find anything wrong. So the problem continues. We did conclude thought that the water is not seeping through the windshield, so it should not be that. Not sure where to do from here...
Did you spray the engine down? Drive thru a river?
If not, the Hood may not be sealing right allowing water to get onto the engine. When it gets into the plug pockets, it usually cooks the coils due to it sparking straight to ground.
If #1 got water in it, then I would say that it has been hosed off or something.
Jimmy
Jimmy
Hi, I got a 2000 F-150 w/ a 4.6L and I went on a longer trip down south about 1000 mile one way trip for a nascar race and got behind a semi in the rain where it was very misty. And my truck started to buck and miss like the the tranny was going. But later that day when it got warmer and dry out it ran fine. But after and over time the check engine light came on for #1 cylender miss Ihad it checked at a parts store. I then got it back home to a ford dealer and they found abad plug, it had small hair line fractures in it so when it got wet it would miss fire. And ford also said that your truck has to go through a # of many cycles of miss firing to have the check engine light come on so you could have some bad plugs. So good luck!
