Changing cam bearings
Greetings all.
I just refreshed my 460 with new rings, main & rod bearings, timing set and oil pump. I did this because I had no oil pressure once the engine warmed up. It's much better now, but the oil pressure still drops to under 10 on the mechanical gauge after about 10 minutes (at 55 mph).
My assumption is that the cam bearings need replacing.
Is this something I can do myself or does it require a trip to the machine shop?
Do the bearings come out the front of the block or out the back?
Thanks in advance.
Kevin K.
Thanks in advance.
Kevin K.
pickenspolitics
18
08-10-2013 07:01 PM
FordEdselFanatic
19
02-13-2009 12:12 PM
KJKozak2
08-05-2003 02:47 PM
highsmith
06-06-2002 06:00 PM
