Lowering my 62 Unibody
Whats up fellas,
Well, heres the deal. I'm currently in the middle of a 62 Unibody restoration and I'm getting to the fun stuff. Finally the sheetmetal is straight and my rustfree tailgate had been procured. Now it's time for powertrain and suspension. There is a 500 cube Cadillac on the stand in my garage awating new life in the 62, which will get a Volaire clip graft and a TH400. For the rear suspension, has anyone ever flipped their leaf spring perches? If I drilled out the hardware holding the perches to the frame and flipped them over, as far as I can measure, there shouldn't be any interference with normal leaf spring compression. Has anyone ever tried this before? Any thoughts?
Thanks!!
T.J.
Thanks!!
T.J.
lowering the rear
You can take the the stock rear end and put it on top of the springs. You will need to C notch the frame about 2 inches.
I used a 73 cougar 9 inch rear its about 1.5 inches narrower than the stock rear on each side and as you well know there is plenty of tire room in the rear of a "Uni" for big meats.
As you can see in the pic below it works well with a Volarie clip and 18x11.5 torque thrust IIs in the rear and 18x9 in the front.
62-05ford
02-03-2013 09:13 PM
