E C U Codes
Old Dec 5, 2003 | 07:52 PM
RazzMaTazz's Avatar
RazzMaTazz
Question E C U Codes
Pulled codes today,got a 58 run code but my haynes book did not list it. I have replaced the entire ignition systom since Oct. Now I have a bad low rpm miss.It is worse at factory timing (10 degrees before) Thanks in advance. P.S. 85 f-150 4.9 4 speed,new; ECU, ignition module, stator, cap, button, wires, plugs, O2 sens,harmonic balancer.
Old Dec 5, 2003 | 08:03 PM
luckild's Avatar
luckild
Are you sure the code is 58? New one on me. Let us know and we'll dig deeper.
Old Dec 5, 2003 | 08:14 PM
brown 4x4's Avatar
brown 4x4
Code 58 is an idle speed control motor code. Check your connections there. Make sure your idle screws are set properly, and/or set the idle according to the emissions sticker under the hood. Let me know if you need more info on it.
Old Dec 6, 2003 | 06:58 PM
RazzMaTazz's Avatar
RazzMaTazz
Thanks Brown, at first I got a 77 cause I didn't hit full throttle in time. Next money I think I'll spend is going to be duraspark+an 83 carb. thanks for everyones help.
TexasGuy001
13
Jun 27, 2023 10:53 PM
T Gould
2004 - 2008 F150
May 7, 2011 04:25 PM
shia1
1978 - 1996 Big Bronco
Dec 19, 2009 12:59 PM
Joetravelall
Nov 6, 2008 06:20 PM
tjlmml
1997 - 2003 F150
Feb 20, 2007 08:50 PM
