'98 E350 Cube w/ No Heat
Old 12-03-2003, 11:47 AM
jagarner's Avatar
jagarner
jagarner is offline
My '98 E350 Cube Van has a problem with the heater. The fan still works fine but the air blows cold. Any suggestions?
Old 12-03-2003, 07:56 PM
pfogle's Avatar
pfogle
pfogle is offline
Check the cable to the blend door and make sure the the heater control valve under the hood is getting vacuum.
Old 12-04-2003, 09:13 AM
jagarner's Avatar
jagarner
jagarner is offline
Thanks, can you tell me where under the hood the control valve is located? I would like to make sure the vacuum hose did not come loose or fall off. Is the cable to the blend door located under the right side of the dash?
Old 12-04-2003, 07:55 PM
pfogle's Avatar
pfogle
pfogle is offline
yes on the cable, the control valve is located near the heaterbox under the hood in one of the line going to the heater core. YOu will more than likely have to remove the air cleaner box to see it.
old farm truck
05-30-2016 11:08 PM
TheBreeze
1999 to 2016 Super Duty
12-02-2011 07:42 AM
ssian
06-24-2010 10:20 PM
Masala
05-20-2009 06:13 PM
RallyCoDriver
12-11-2003 10:06 AM
Quick Reply: '98 E350 Cube w/ No Heat
