Heater Hoses
Old 11-24-2003, 04:11 PM
murder4hire's Avatar
murder4hire
murder4hire is offline
Heater Hoses
On my '92 4.0, which heater hose goes to the block and which goes to the intake manifold?
Old 11-24-2003, 07:26 PM
murder4hire
Could someone please just take a quick look?
Old 11-24-2003, 08:30 PM
Ken00's Avatar
Ken00
Ken00 is offline
It really dosen't matter but I'm sure someone will look, I don't have a 4.0.
Old 11-24-2003, 08:55 PM
murder4hire
It doesnt matter? I thought it ran in a loop.
Old 11-24-2003, 09:07 PM
Ken00's Avatar
Ken00
Ken00 is offline
The only thing you change is the flow through the heater core. I'm sure someone will answer but you'll be OK with it connected either way.
You do mean heater and not radiator hose.
Old 11-24-2003, 09:09 PM
murder4hire
Yes, the 2 hoses running from the left side of the firewall to the engine block and intake manifold.
Old 11-24-2003, 09:10 PM
Ken00's Avatar
Ken00
Ken00 is offline
You'll be OK and you can always switch them at the core without losing much coolant when someone with a 4.0 stops by.
Old 11-24-2003, 09:12 PM
murder4hire
alright, thanks
Old 11-30-2003, 05:50 AM
DadsrII's Avatar
DadsrII
DadsrII is offline
On my 92 4.0 the hose closest to the blower motor goes to the water pump.
Ken are you sure it doesent make a difference? I would think the hose that goes to the bottom of the heater core should be the inlet to force the water upwards to keep the water in the heater core longer to transfer heat from the water to the core, providing hotter air, as opposed to the water running down through thre core and escaping faster. I don't think any damage would occur reversing them, unless the reverse flow started to remove scale deposits, But I would think efficiency wise it would make a difference. Not sure only questioning the facts to satisfy my couriosity.
Old 11-30-2003, 09:03 PM
Ken00's Avatar
Ken00
Ken00 is offline
The water is under pressure from the pump so I don't think that would matter. Also some cores lay flat.
Old 12-02-2003, 09:34 PM
kevinswart's Avatar
kevinswart
kevinswart is offline
I agree Ken it should not matter.
Old 12-02-2003, 09:43 PM
murder4hire
Alright, I put them how DadsrII said to put them anyways, just in case, thanks guys.
