LIGHTNING / HARLEY DIABLOSPORT PREDATOR NOW AVAILABLE!! o
on
Lightning / Harley Diablosport Predator Now Available!!
Predator for 1999 - 2004 Lightnings & Harleys with factory Supercharger<hr><img src="/Web_store/Images/04SVTLightning05_pk.jpg" hspace=6 vspace=6 align=right><b>Dyno Tested Performance Tunes</b>
<BR>Diablosport has generated dyno tested tunes for 1999-2004 5.4L-2V Ford Lightning and Harley Davidson F150 applications with Supercharger.
<b>Dyno tested tunes for factory Supercharged Lightnings & Harleys</b><li>3 Standard Tunes for 2001-2004</li><ol><li>Tune 1 - For Factory Stock Boost Level</li><li>Tune 2 - For up to 12-14 lbs of boost total (+4 to +6 over factory)</li><li>Tune 3 - Factory Stock Tune: allows use of below end-user options with factory tune.</li><br>Average power gains are in 20-30 HP in the Supercharged SVT vehicles.</ol><li>5 Standard Tunes for 1999-2000 Lightnings</li><ol><li>Tune 1 - For Factory Stock Boost Level (8#'s)</li><li>Tune 2 - For up to 12-14 lbs of boost total (+4 to +6 over factory)</li><li>Tune 3 - For Factory Boost Level (8 lbs) for Ford 90mm MAF</li><li>Tune 4 - For up to 12-14 lbs of boost total (+4 to +6 over factory) for Ford 90mm MAF</li><li>Tune 5 - Factory HP Tune (Stock Tune): Factory calibration tune only (allows use of below end-user options with factory tune).</li></ol><b>Diablosport Predator Performance Tunes Features</b><ol><li>Remap of Fuel Curves</li><li>Remap of Timing Curves</li><li>Raise Speed Limiter</li><li>Raise Rev Limiter</li><li>Remap Part and Full Throttle Shift Points</li><li>Remap Shift Timing and Shift Pressure</li></ol>
<b>Diablosport Predator allows the user to make the following tuning adjustments</b><ol><li>Idle adjust for both drive and neutral</li><li>Axle Ratio adjustments from 2.xx up to 5.xx in .10 increments</li><li>Fuel Base adjustments from -15% to +15% for PE mode</li><li>Spark Advance Timing adjustments from from -10% to +10% for PE mode</li><li>Rev Limit adjust for both drive and neutral. Adjust ON/OFF rev limits, for each individual gear, in 10 rpm increments. Up to 6000 rpms on Lightnings/Harleys.</li><li>Adjust Shift Points in 50 rpm increments for each gear</li><li>Shift Firmness adjustment for each gear</li><li>Allows turning of Bank 1 and 2 Rear Oxygen Sensor ON/OFF, or ALL O2's ON/OFF, AND EGR system.</li><li>Wheel/Tire Size adjustment of speedometer for larger/smaller tires.</li></ol><b>Diagnostic Capabilities</b><ol><li>Read and erase fault codes, and contains all the Ford specific P codes. </li><li>Diagnostics will work on all 96-present OBD-II Ford Mustangs or F-Series Gas vehicles.</li></ol><b>Live Data Logging and Monitoring Capabilities</b><ol><li>Monitor over 400 tuning parameters.</li><li>Log live tune data at 90 samples per second, for at least a 30-minute period. Can be viewed on the Predator screen or be transferred to a PC, either live or logged, using FREE software supplied by DiabloSport.</li></ol>
<b>Special Features</b><ol><li>The only flash tuner that allows for end user adjustability to the performance tune, enough adjustment to allow for pulley changes in factory-supercharged engine applications.</li><li>The only flash tuner which accepts custom DiabloSport programs, and can be done via using email/internet through your dealer.</li><li>The only flash tuner with advanced diagnostic capability.</li><li>The only flash tuner with data logging and monitoring capability.</li><li>Backlit screen which is 300% larger then the competition’s screen.</li></ol>
<hr width=95%><p align=justify><b>FREE OVERNIGHT SHIPPING!!! (Continental USA only). Predators ordered before 2:00 pm EST will ship the same day.</b> See our polices page for details. <p align=justify>We the largest Diablo programming dealer in the world.<br><font color=red size=2 face="verdana, arial, helvetica"><b>Call toll free 1-877-399-6417 or 770-806-1955 for specials/combo packages.</b></font>
<b><font color=red>AVAILABLE NOW!</font></b>
See http://www.motorhaven.com/customer/home.php?cat=211
JoeFin
06-08-2022 09:53 AM
fusefinder
Toy Hauler Towing; Fifth Wheel & Bumper Pull
08-14-2016 09:35 PM
460f150explorer
05-21-2001 05:19 AM
