Will I Need To Remove My 460 beast to put Hedman Hedders On?
Old 05-12-2001, 10:44 PM
460f150explorer's Avatar
460f150explorer
460f150explorer is offline
I want to get Hedmand headers real bad and need to know what problems I will run into with my 77 Ford F-150 2x4. I know I will need a heat sheild and stuff but I don't want to remove my motor.
[font color=blue] [b] [u]77 Ford F-150 Explorer 2x4
[ul]
[li]460 big block(stock)
[li]P275 60R 15 tires
[li]Jensen CD player with 2 Pioneer 180 watt 6.5 inch door speakers and 4 other speakers behind seat
[li]Flomaster 40-Series mufflers
[li]2.5 inch aluminumized pipe with turndowns before the axle.
[li]14 inch Edelbrock chrome air cleaner[/ul]
Old 05-13-2001, 08:50 PM
chopper's Avatar
chopper
chopper is offline
I bought a 1968 F100 with a 429 in it. It is equiped with headers. It appears that no modification was needed on the drivers side. The passenger side, however, had to have the frame notched to work. It appers to have been a very hurried job with a cutting torch. I plan to do a little work with a grinder and clean it up a bit.
I would guess that a similar modification would be required with your application. Looking at how tight mine is, I just dont see how a clean cut would be possible with the engine in place.
Old 05-15-2001, 11:17 AM
dre's Avatar
dre
dre is offline
Did not have to remove engine on my 78' 2wd.
Had to notch the Pass. side frame with grinder.
jacked motor up a tad.
Dre'
1978 F-150, 460ci(750cfm,Edelbrock Performer,Dynomax Ceramic Coated headers,etc.)Auto-C6,3:70.1 - 9" Posi.
Old 05-20-2001, 12:19 AM
bigsnag's Avatar
bigsnag
bigsnag is offline
Did you come in from the top or from the bottom when you put the headers on????
Old 05-21-2001, 05:19 AM
laptopgeek's Avatar
laptopgeek
laptopgeek is offline
Marfa
01-25-2017 03:39 AM
Bishop1986
1997 - 2003 F150
09-17-2016 09:44 PM
Snakeoiljoe
Arizona Chapter
02-10-2016 01:22 AM
2006powerstroke90
02-08-2012 01:25 PM
FTE Ken
Computer Chips & Tuners
11-20-2003 01:02 PM
Quick Reply: Will I Need To Remove My 460 beast to put Hedman Hedders On?
