power stroke torque curve
Go to www.edgeproductsinc.com/ford-ez03-chart,html they have TQ chart for all the diesels also might want to check out www.quadzillapower.com/2003_ford.htm I printed them out they both seem to be different I don't know witch one to believe maybey one is engine hp/tq and the other is rear wheel hp/tq hope this helps Jerry
There's two at www.cummins.com. Click on USA/Canada then go to products, Dodge Ram, Cummins Turobe Diesel. At the end of the 2nd paragraph there is a link for the torque curves. The first one is the standard output and the second one is the high output (there's 2 pages and the high output is on the second page). For some reason, every link i tried does not work. If i click on it, it doesn't take me to cummins.com so you might have to type it in manually.
Glad I could help I also think cummins is the most durable and eisiest engine to modify thats why banks chose it for the side winder dakota project now if they could just get a tranny as good as the TQshift and put some room in the crew cab. both dodge and chevy cant compare to the room in the ford crew cab and I have a family
Duneitic
08-03-2015 09:21 AM
Tall Paul
12-03-1999 10:34 AM
