my steering wheele lock won't unlock
Old 11-04-2003, 10:09 PM
forddytube's Avatar
forddytube
forddytube is offline
Unhappy my steering wheele lock won't unlock
guys , i can't unlock my steering wheele to start my truck, it's a 1991 f-150. for some reason the key goes in but won't unlock the steering wheele lock.i have tried everything.
can someone please tell me if this is something i can do on my own at home and what will i need.
i know i have to turn the key to the on position to get the lock pin and pull the lock out ,but now that the key is stuck locked what do i do to release the pin. please help .
Old 11-05-2003, 12:36 AM
lexluthr69's Avatar
lexluthr69
lexluthr69 is offline
Try putting a decent amount of pressure on the steering wheel in either direction, while turning the key. Did you park on a hill, or have the wheels turned hard when you parked last? A lot of times the pressure to the steering system will drop, when you turn off the truck, and the steering will try to straighten the wheels, locking the steering wheel even harder.
Old 11-05-2003, 04:49 AM
wrh's Avatar
wrh
wrh is offline
Remove the plastic cover on the bottom side of the steering column. On the side of the housing that holds the lock cylinder you'll see a small hole about 1/8 inch diameter. Insert a center punch or similar object to depress the retainer and the cylinder should pull out. Your key might also be worn, thats what happened on mine anyway. Good luck.
Old 11-05-2003, 07:42 AM
forddytube's Avatar
forddytube
thanks for the tips guys ,i will try to remove it later when it warms up outside ,theres ice everywhere.
wrh
willthe retainer still pop out whilst lock is locked or does it have to be turned to the on position? which i cant get to turn.
the key s seem ok i'm thinking maybe the whole lock is cooked cause i did notice it getting stiffer and stiffer to turn.f**k!
Old 11-05-2003, 12:21 PM
forddytube's Avatar
forddytube
f**k , i had to distroy the whole lock by forcing all sorts of stuff in it and i had a thousands of fragments of the lock everywhere, so i went to checker for a replacemaent and just put the thing back in there ,and it works.
thanks guys!!!!!
F.T.E RULES !!!!!!
dolphans1
1997-2006 Expedition & Navigator
06-25-2017 03:31 PM
Roberto Brigati
Escape & Escape Hybrid
02-16-2016 05:19 AM
King Ranch
2015 - 2020 F150
01-22-2016 08:23 AM
Rscottc
11-16-2014 02:46 AM
Wren
02-03-2009 08:11 AM
Quick Reply: my steering wheele lock won't unlock
