Motorcraft 2150 Enrichment valve?
Old 11-03-2003, 06:31 PM
Skagit's Avatar
Skagit
Skagit is offline
I rebuilt my carb last thursday, Motorcraft 2150 sitting on a 351m in a 1981 Bronco, it went smoothly except the "Power Valve" wont fit. The kit was NEIHOFF, 50$ , and the valve is to long for the cover to fit back over it. Is there a way I can buy a deeper cover for this new valve or will it even work? Thanks for the help.
Old 11-04-2003, 08:31 AM
LxMan1's Avatar
LxMan1
LxMan1 is offline
It sounds as if you got the wrong valve. I would look at another kit to see if maybe it was packaged wrong.
Jimmy
Old 11-04-2003, 06:21 PM
Skagit's Avatar
Skagit
Skagit is offline
They gave me a piece of paper in the kit saying that it would look different than the origional, but it is too long for the cover to fit over it.
Old 11-05-2003, 01:26 AM
bubbaf250's Avatar
bubbaf250
bubbaf250 is offline
Your kit came with a two-stage power valve and your carb needs a single-stage unit. The two-stage valves are longer on the bottom.
You can scavenge a bigger power valve cover from a junkyard carb, or raise heck with the store that sold you the kit. You might not get very far with the store because the kits have those lovely warning notices that once you open the parts bag, they wont take the kit back.
Another alternative is to get just a power valve. You can still get them from Ford dealers as a Motorcraft part. You might be able to get them from a chain parts store too, but the only one I've had any luck with on parts like that is NAPA.
To get the right valve, you need to figure out what vacuum the valve should open at. If the old valve is not broken, you can put a vacuum on the diaphragm with a vacuum guage attached and see where it closes.
Check out this page for Motorcraft part numbers for power valves:
http://home.earthlink.net/~bubbaf250...rb/carb10.html
lshort
11-01-2015 05:18 PM
mad2smile
09-04-2013 02:49 PM
samahi72
02-13-2008 11:19 AM
thedirtyneck
05-10-2004 04:28 AM
ClatonK
01-02-2004 12:52 PM
Quick Reply: Motorcraft 2150 Enrichment valve?
