1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
P0133 O2 sensor...Bank1 Sensor1???
Old 11-01-2003, 03:57 PM
kamsho's Avatar
kamsho
kamsho is offline
Hi, my 97 Expedition (4x4 5.4L) 's check engine light is on.
Code reader shows p0133 which means O2 sensor Circuit Slow Response Bank 1 Sensor 1.
Is this means I need to replace the O2 sensor?
Is Bank 1 the driver side or persenger side?
Is Sensor 1 before or after the cat?
Thanks in advance for you help
Kam
Old 01-20-2004, 11:36 AM
jwalker's Avatar
jwalker
jwalker is offline
Have you found out where the location of the oxygen sensor is when the ODBII tester referes to Bank 1 Sensor 1. My truck has the same issue.
I also have 1 and 2 misfiring along with other things. So I guess I could cross reference which side cylinder 1 and 2 is on, but thought I would ask you to see?
Old 01-20-2004, 12:15 PM
buzzard's Avatar
buzzard
buzzard is offline
Bank One is a multinational bank holding company in the process of merging with JP Morgan Chase......
Bank 1 is the driver side #1 is upstream. IF one has failed, you might as well replace the pair of upstream units at the same time. They are normally good for 80K to 100K miles.
Old 01-20-2004, 02:57 PM
Phil056's Avatar
Phil056
Phil056 is offline
Just wondering if it's a PITA to change the sensors? and if not, any special tools required? I'm around 112k and I don't think any have been changed since the truck was new (checked all the receipts). I've just changed my plugs this past weekend, and you want to talk about a PITA!
Thanks,
Phil
Old 01-20-2004, 04:05 PM
buzzard's Avatar
buzzard
buzzard is offline
Thanks,
Phil
I've heard the passenger side is tough to get to and might require removal of some nearby components. If you were able to do the plugs, you should be able to tackle this too.
rogerranger2122
1983 - 2012 Ranger & B-Series
23
08-08-2016 06:24 PM
Emsand1
05-15-2016 10:45 AM
lacyctdy
05-02-2016 11:53 PM
tbush08204
01-20-2016 07:29 AM
air1jpg
2004 - 2008 F150
02-19-2014 09:22 PM
Quick Reply: P0133 O2 sensor...Bank1 Sensor1???
