Rims
I would ask the ford shop,. they have all that info on file. They can tell you what rims swap with what. I would just goto www.centerlinewheels.com
POS_F250,
All Ford 8 lug pattern for the clear up to the '97 F-250HD and '97 F-350 will work, the pattern is 8 on 6.5. The new 99+ F-250 and F-350's will not fit, the bolt pattern is metric, 8 on 125mm I believe. Chevy and Dodge both use the 8 on 6.5 bolt pattern for their 8 lugs, so they will interchange. Hope this helps. The full floater Sterling 10.25 rear axle in your F-250 will require some deeper center caps, as Dodge and Chevy's rear hub is not as deep. The Dodge and Chevy rear caps will not work. Have a great day.
chevy wont fit anything but chevy, but ford and dodge will fit on chevy. although i'm not sure if dodge and ford are swapable. they have the same bolt patterns but the hubs are different sizes i'm assuming, since chevy will only fit chevy. Bt the way i figure it,first hand experice is the best
Also the rims from a Jeep will fit. I have had a few old CJ-5's and CJ-7's and have swapped rims from my 1978 F-150 to Jeep to 1994 F-150. They are all the same as long as the measurements are 5 on 5.5. I honestly didn't know Chevy ever used that pattern but thanks for the info.
