460's are pre fuel injection blocks the same as fuel injected blocks
I need to know if the older 460 blocks are the same as a block on a fuel injected 460. Would I need to swap my heads to the older block or will they even fit? Will my fuel injected manifold fit on an older style block? Will there be any other problems? Will the motor mounts be the same? Any Info will be appreciated. Thanks
You'll need to use the EFI heads to use the EFI intake manifold. They both have a different angle than the carbed heads and intake manifolds. Someone posted on using the EFI maifold on pre-EFI heads, but made it clear that its not a no-brainer project. For all pratical purposes, the blocks are the same.
lighttruck
05-23-2011 03:19 PM
hotrob
11-29-2006 07:36 AM
tturvy
09-29-2003 04:06 PM
