PCM trouble code PO340 help needed
Old 10-16-2003, 01:10 AM
Wilcoman's Avatar
Wilcoman
Wilcoman is offline
I have a 1995 Ford Ranger 4.0 six cylinder that has recently had frequent check engine light problems. The light comes on, I take it to the mechanic and he tells me it has to do with the cam sync sensor, and with the PO340 code it should be running really bad or not even start. However, the truck runs fine with an intermittent misfire on the freeway every so often. Other than that all is working well. So he resets the light and after a period of time it comes on again. This has happened about 4 or 5 times in the past 2 months but my truck doesn't seem to be running badly at all. I even drove it for a week with the light still on and no difference was noticed. Does anyone have any ideas on what is going on here? I hate to take it to the dealer and have them ream me unnecessarily. Any help would be appreciated. Thanks Bill
Old 10-21-2003, 08:47 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
Hi, welcome to Ford Truck Enthusiasts!
The camshaft position sensor (CMP) is easy to replace. Unplug the wire harness connector, remove the two screws, and that's it. Installation is the reversae of removal. If your problem is simply the sensor, then you can easily fix it yourself.
The CMP is located behind the intake manifold on the top surface of the cylinder block. It looks something like this (3.0L shown, 4.0L similar):
Hope this helps ...good luck!
Dylanpan214
65
04-05-2021 03:19 PM
John Canada
1947 and Older Ford Trucks
22
03-25-2017 01:11 AM
Lsvare
1997-2006 Expedition & Navigator
09-11-2015 11:43 PM
werefour146
Aerostar
16
04-04-2013 04:14 PM
samthemountainman
2004 - 2008 F150
02-18-2012 02:46 PM
Quick Reply: PCM trouble code PO340 help needed
