1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
What type of gear oil???
Old 10-09-2003, 03:30 PM
bronco351's Avatar
bronco351
bronco351 is offline
HI, I own a 1998 Expedition Eddie Bauer. It has the limited slip 3.73 ratio rear axle. It's time fo rme to change the fluid in it. The thing is I don't know what kind to buy. Does it use a special fluid only dealerships have, or is it the cheaper gear oil that Pep-boys sells. I would really apprecaite all your help!!
Old 10-09-2003, 03:45 PM
Prowler826's Avatar
Prowler826
Prowler826 is offline
Dealerships will absolutely overcharge for the product.
If you use a standard petroleum 75w90 gear oil, you'll need to add a tube of friction modifier for the LSD, otherwise you'll foam out!
Probably a better choice would be a full synthetic 75w90 or 75w140 (if you do any towing). I prefer Royal Purple (about $8 a quart on the 'net) - it requires no friction modifier. Neither do brands like Amsoil or Redline.
You can find Mobil One gear oil at your local auto parts store - not sure if you need additive with that or not - read the label. But stick with the synthetic - it's better in the heat!
Old 10-09-2003, 07:22 PM
bronco351's Avatar
bronco351
Thanks, I just have one more question. I want to use a gasket this time instead of silicone. What is the name of the axle my expedition has?? Is it the 10.25 sterling. Thanks a Bunch!!
Old 10-09-2003, 07:59 PM
southprk's Avatar
southprk
southprk is offline
Your expy actually calls for synthetic in the differential so make sure to use it. I had oil express do it for $35 - seemed worth it to me!
Old 10-09-2003, 08:18 PM
PaulC's Avatar
PaulC
PaulC is offline
Use Motorcraft Synthetic Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
The friction modifier additive for limited-slip diffs is Ford Additive Friction Modifier C8AZ-19B546-A or equivalent meeting Ford specification EST-M2C118-A.
Put the friction modifier in first, then fill the rear diff (whether it's the 8.8" or 9.75") to a level 6.4 - 14.3 mm (1/4 - 9/16 inch) below the bottom of the fill hole.
Old 10-09-2003, 08:20 PM
BigMattXXL's Avatar
BigMattXXL
BigMattXXL is offline
AFAIK, for the LSD, Ford calls for 75w120 + friction mod. I haven't seen 75w120 anywhere but at the dealership (figures) and it's like $30/Qt.
Redline makes an 80w120 syn lube with goes for about $8/QT. I'm probably going to go for that - Redline is a great company.
I think the usual axle for these trucks is the 8.8, unless I'm mistaken.
XXL
Old 10-09-2003, 08:58 PM
buzzard's Avatar
buzzard
buzzard is offline
I think the "rule of dumb" (if not 100%) is 8.8" for the 4.6L and 9.75" for the 5.4L. The front differentials are 8.8's".
OK, I just looked in my manual, the rear differential calls for 75W-140 and the front differential calls for 75W-90 (Plus friction modifier if LS).
FYI, the 9.75" rear has 12 bolts on the cover and the 8.8" has 10 bolts.
Old 10-09-2003, 09:09 PM
boxcar_tommie22's Avatar
boxcar_tommie22
boxcar_tommie22 is offline
i have 98 expy there is a tag on my diff. that says to use 75w140 synthetic so i added fords additive and i bought redlines 75w 140
Old 10-09-2003, 09:10 PM
boxcar_tommie22
also my axel is a locker
Old 10-09-2003, 09:11 PM
PaulC's Avatar
PaulC
PaulC is offline
The shape (outline) of the diff covers is not the same. The 8.8 diff cover is pretty much symmetrical when comparing the right side to the left side, while the 9.75 cover is relatively rounded on the left side and somewhat triangular-looking on the right.
Old 10-09-2003, 09:12 PM
vics97xlt's Avatar
vics97xlt
vics97xlt is offline
i thought that the fluid in the rear was good for life unless there were signs of a leak?
Old 10-09-2003, 09:16 PM
PaulC's Avatar
PaulC
PaulC is offline
If you take the truck for a little bath in a river or stream, you may need to change it (water contamination). Never hurts to change it anyway to flush out metal particles from normal wear.
Old 10-09-2003, 09:25 PM
BigMattXXL's Avatar
BigMattXXL
Depends on your definition of "good for life" - Ford seems to plan for people not keeping these trucks past 120K miles or so.
As PaulC said, there's no good reason not to flush the rear differential - cheap insurance for a costly failure.
XXL
Old 10-09-2003, 09:28 PM
BigMattXXL's Avatar
BigMattXXL
My rear diff uses 75w140, BTW, not 75w120 as previously stated. I haven't dealt with this in over a year - memory isn't that good
I'm going to peek under there tomorrow - I can't remember which rear I've got. I thought it was an 8.8", but who knows....
I certainly don't
XXL
Old 10-09-2003, 09:34 PM
southprk's Avatar
southprk
southprk is offline
I think the ford maintenance guide says every 60k miles. I had a dodge dakota for about 150k miles and never changed it, never had a problem with it - different animal though!
Quick Reply: What type of gear oil???
