rear end
rear end
hey everyone,
i have a 1990 bronco with 31 inch tires and a stock 3.55 rear end. since the bronco did come with 31 inch tires, i was wondering what would be the best rear end to put in it for more power on the start. right now i dont have any power in over drive at all so i pretty much never put it in over drive unless i am coming down a moutain or soemthing so i always drive with the thing in drive. at about 70 or 75 mph i run like 3000 to 3100rpm in drive. i was thinking of a 4.10 or a 3.90
also, i put headers and true dual exhaust on the bronco and put the o2 sensor back but only on 1 side since it only has 1 o2 scensor, but it seems liek sometimes the truck has trouble figuring to run rich or lean or perfect and i was wondering if anyoen has every had this problem or might know of another reason for this problem.
thanks a lot
thanks a lot
If he goes to a deeper gear it'll allow him to use o/d and thus drop the revs. if the gearing is too high you have no power in o/d and it'll barely maintain speed. a deeper gear will bring this power up a bit and will also bring the revs up a bit (but they'll still be lower than driving in D with the higher gear).
Justin
Justin
hey justin, do you have any idea what i should try? either 4:10 or 3.73 like you said, i dont have any power in overdrive and i dont need a top speed of over 100 with is rediculous in a bronco. i have 3.55 now with 31 inch tires and the stock tires where 28 inches tall. thanks for the advice
(i now i'm the wrong Justin, but i can help you out ) If you threw a set of 4.11's in there you'd be equivalent to a 3.54 and stock tires, right now you're equivalent to a 3.08 and stock tires. the 3.08 is a great highway gear if you have a 1:1 top gear, but with the O/D go with 4.11's. The 3.54 is a great "compromise" gear, you don't lose too much on the bottom or the top, it's a solid midrange gear. This can also vary with which motor you have. With a 302 i'd want a 4.11 equivalent gear, with a 351 a 3.7, and a 300 a 3.54 because of the different rev ranges they operate in. Sorry, if you have a bronco II and a bent 6 or something like that i can't be of much help but i'd just keep going deeper.
Justin
EDIT: I goofed, those numbers are for 33's. Drop the numbers about .25 and they'll all be correct for 31's.
Justin
