Specs on 460 engine
Specs on 460 engine
Unless you are towing something really big, I agree, the 460 will handle most loads just fine. I tow a 30 foot trailer whose dry weight is over 8,000 pounds just fine and most hills don't even make it kick down to 3rd.
Usually the limitations have more to do with the frame, axles and springs. Most magazines say that if you want to tow a heavy load(5,000 or more) regularly, then you should go with a 3/4t or full ton truck, they usually don't worry about the engine unless the load is really heavy. The heavier trucks usually have stronger axles, trannies and springs and normally have other things taken care of like coolers and bigger radiators. You are penalized however by the extra weight of those things so gas mileage can be poor. My 94 F250 4x4 supercab gets 12 mpg on a good day, no load. But then it drops only to 9 or maybe 8mpg on a bad day with a heavy load.
I would recommend a tranny cooler if you have an auto. A good hitch and sway bars for the hitch are highly recommended if you pull anything much heavier than say 2,000.
Hope this hleps.
Jim Henderson
Hope this hleps.
Jim Henderson
zgraham
09-03-2013 10:09 PM
daddylee100
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-17-2013 05:48 PM
aidenn
06-16-2005 11:04 PM
melisa
03-01-2004 01:36 PM
