Performance spark plug wires?
I am planning to replace plugs and wires on my ranger, and am interested in anyone's experience with aftermarket performance wires. I was lookng at Taylor wires, 10+ mm, and the pricing is about right, 60.00 a set. Anybody else try these yet, I am open for suggestions.
Not to pop the ballon or anything, but if you're looking for more spark power, you should look at the coil block first instead of the wires, go to the source of the electricity and not to the conductor. Granted that the wires will give you a cleaner conduction, but the spark is the same, unless you increase the power to it. I might be wrong, but is something that I learned while in college (B.S. in Electronics - 14 yrs ago). Just adding my .02.
P.S. Just my opinion and trying to save you $60. If I'm wrong, please enlighten me, I'm here to learn new things
thing you can do is make sure you use double platinum plugs when you replace them.
Well, at least I got some kind of answer. And yes, I do know the advantages to installing aftermarket wiring. What I am mainly after are any specific recommedations, anybody who has actually replaced the factory cables with an aftermarket set, and their experiences thereof, as to fit, quality, possible driveability issues, etc. I am not interested in investing thousands of dollars to build a race truck, I just want an efficient running pickup, to acheive the best possible fuel mileage and maintain the best performance possible.
Ranger, my guess that is because the higher spark from the aftermarket wires were heating up the cylinder more. My guess is that your stock wires are bad, and not causing enough spark to heat up the chamber properly. I would put the aftermarket wires back in, then either put in a phenolic spacer, or use higher octane fuel.
