Carb Problems on a 390 FE
Im having a slight problem with my 390.
I go to fire it up, it acts like its out of gas...
I dump some gas in the carb, it fires up and I have to keep it running for a second before it pumps fuel.
Whats the problem?
The fuel pump is good, the carb is in good shape
and I have no leaks.
It didn't do it with my 2 barrel set up before rebuild
and it didn't do it as much w/ the 650 Holley I had
Now i have a 750 and I don't know whats wrong.
Any help would be appreciated
Whats the problem?
Hi,
Sounds like to me that somehow your front bowl is not holding fuel and you are starting with it empty.
You say it is not leaking on the outside , but ( I am grasping at staws here) could it be leaking internally into the intake? How long does it have to set before you have trouble starting it? Over night? A few hours? Minutes?
Good luck,
Good luck,
73 fourxfour
12-27-2010 01:35 PM
JoeSwing78
16
08-21-2008 07:34 PM
