The downside of chips and tuners......
<!-- I've done a few of the microtuner modifications to customer's fehicles, and I've been impressed with the results so far..... ---> My question is in this "you don's get something for nothing wold", what is the downside to chips and microtuners, other than needing to use high octane fuel? Also, since i've not done one to my own truck, what can be expected gains using either a chip and microtuner, and i mean everday driving, not on the dragstrip. Does this gain equal or exceed the cost of the upgrade, and how much horsepowe or torque does one need to gain to "feel" the difference? Thank you for any info.
Dube
Dube
I understand that premium fuel is required, but why is it required, what is EGT, and why aren't the trucks programmed like this from the factory? Does anyone have a lot of miles on a chipped, or microtuned vehicle? By that i mean have they put on a lot of miles since they changed the programs? I'm looking at the long term drawbacks. I've heard they blow out injectors after a long time usage? little help?????
on
The increase timing and because premium requires more air for a complete burn (ie, to produce more power) they lean the fuel out slightly.
EGT = exhaust gas temperatures
I have customers who have been using chips for years without problems (I also fit into this category). Never heard of blowing out injectors.
One concern I have about chips is Warenty implications. I know if you have a chip and something unrelated goes they have to fix it, but what if the computer craps out, whether or not it was caused by the chip my guess is Ford will blame it on the chip and not want to fix it. Are there any other engine problems they might try and blame on the chip? If I tear apart the M5OD in my Explorer will Ford say it was caused by the increased power from the chip? If you remove the chip can Ford determin if you ever used one?
Found this over on texasdiesel.com:
The Magnuson-Moss Warranty - Federal Trade Commission Improvement Act of 1975, protects you. Under the Magnuson-Moss Act, any after market equipment which improves the safety or performance, does not void a vehicle warranty, unless the warranty clearly states in the owner's manual that these additional items void the warranty. The dealer must also prove that an added, after market or safety item caused the need for repairs before they can deny warranty coverage on that basis.
Hope that helps...
Hope that helps...
on
No they don't. Read it very carefully. They are very careful in their wording to imply all sorts of nasty things without actually saying it because they know its against the law. They can't void the warranty for installing a chip or using a tuner. They can, however, refuse a repair caused by an aftermarket part. Cause -vs- installation, huge difference.
Originally posted by Badger
...if they can prove that the aftermarket part is the cause of the problem.
Typically in an electronic part, if there is a defect, it will fail either immediately or within the 1st 90 days- both cases would be covered by warranty. As far as taking the ECU with it when it goes- probably not unless there is some easily verifiable defect in the chip itself. Some defect like shorted out leads- but that would be discovered when the chip is originally programmed.
Tim
bubbaump2002
07-26-2004 08:27 PM
BigMattXXL
1997-2006 Expedition & Navigator
15
08-25-2002 07:24 AM
