Supercharged Expedition Help
Hey guys,
Yup, I'm new here and I already need help
Here's the problem.
I bought a Powerdyne SC from a shop online brand new.
Had a local shop install it on my 2k Expedition with the 4.6L .
Install went fine and soon I was on the road. I now have a light vibration coming from the break & gas pedal. I could live with that.. Bigger issue is the motor stalls during stops. Like it is either short on gas or air.
I have an appointmet this Saturday for the mechanic to go through it again but I thought a few extra ideas from you people to discuss with him would be beneficial.
And yes, under full throttle it MOVES.
Thanks for any help.
-Deez-
Here's the problem.
-Deez-
Well, I have the intake run into the side engine bay fender hole, just like the set-up says to have it. As for the fuel, there is an FMU unit that hook sup that is supposed to aid with the extra fuel that is needed. I will have "words" with Powerdyne tech support tomorrow and will post back here what they say.
It's real unfortunate on my part I didn't reasearch this further. Today I typed in " Powerdyne problems " into Google and it returned enough hits to make my stomach turn.
-Deez-
-Deez-
Lesse,
It only happens when I am about to be in a complete stop. Like 2 MPH or less. And it will either surge up and down a hundred RPS or so and then either die or recover. It's like when the tranny usually switches gears or whatever happens underneath when you are preparing to stop. Wish I could describe it better.
I can't really blip the throttle because most of the time, it's a suprise "I'm dead" situation.
Hey, I'm new to this also
But I'm having the same problem when I come to a stop my rpm's jump up and down and sometimes the it cuts off on me. I added headers, air intake, mass airflow censor, stage II chip, throttle body spacer(helix power tower). true dual exhaust flow master 2 1/4. I have no idea what to do
Thank you for saving me from buying each one of those trying to solve my problem.
What are your specs?
I talked to the Tech guy at Powerdyne. He seemed stumped.. That's nice. He seems to think there is a Fuel delivery problem or an air leak.
So I scheduled an appointment with a local speed shop to see if they can solve it.. If they can't, I will be trying to return the unit.
Good luck to you!
-Deez-
Good luck to you!
-Deez-
Originally posted by Deez
Lesse,
Lesse,
I'd try taking it back and going with a Ken Belle setup - I've heard nothing but good things about them.
Good luck and keep us posted
XXL
