Hurst Shifter for M5OD
Old 09-25-2003, 09:19 PM
sandrat's Avatar
sandrat
sandrat is offline
I saw Hurst makes a shifter now for the M5OD. Just wondering if anyone has one or has dealt with one, and what they think of it.
Old 10-02-2003, 10:06 PM
FlaresideGlenn's Avatar
FlaresideGlenn
FlaresideGlenn is offline
I installed a Hurst Bullet short throw shifter in my 1994 F150 when the stock one failed. It was alot cheaper then the factory Ford replacement part, it shifts better and looks cool as well.
The installation took about 2 hours - you simply remove the old one and re-install the new one, replacing all the mounting and retaining bolts as required.
As an added bonus, I can now install any Hurst shifter handle or **** - with the Ford shifter you don't have alot of options unless you want to drill or re-tap a new handle to fit.
Hope this helps, Glenn
billest
10-24-2013 08:28 PM
kfcoltn
05-01-2009 10:24 AM
captainkirk
09-26-2005 11:28 AM
Quick Reply: Hurst Shifter for M5OD
