loud metal clicking from engine
Old 09-22-2003, 05:43 PM
airchief's Avatar
airchief
airchief is offline
ok ineed help. Went to crank the 97 f150 4.2 and a clicking sound starting went up rpm and down. removed all lifter and push rod..looked.ok. Does anyone think it might be the water pump..HELP!!
Old 09-22-2003, 08:28 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
Hi airchief and welcome to FTE
How many miles on the truck? Any other symptoms? Use any oil or coolant? Can you describe the noise better?
Old 09-23-2003, 06:56 PM
airchief's Avatar
airchief
airchief is offline
truck has 108,010. Symptoms... sometimes seems to crank rough at first then gains rpm to steady out. this time is just creak..then sounds like metal tapping. going up with rpm and down.
removed the lifter and pushrod, checked cleaned and reinstalled. turned it over with the valve cover off, oil pumped, gapped checked.
removed the water pump, noise heard from behind water pump. Could this be the timing chain or crankshaft...help!!!
ps also checked the starter fro being hung. checked 4.0 and remove all spark pulg. I can get one full turn on crank before it locks up with spark plugs..
Old 09-23-2003, 09:01 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
I'm wondering if you dont have the dreaded 4.2 coolant in the cylinders problem. If you do a search on here you'll find more info on that.
Also take a look at www.leakingfords.com
