what Carb?
what Carb?
well first off do you want a 2 or 4bl. if it's a 2bl holley does make them. if you want a 4bl go with a Edelbrock 600 or 650 vac sec. i never owned one until i bought my latest truck, it came with it. they are VERY easy to work on. it's only a 2 piece body and holley is a 6 piece. more chance's to leak.
as for good gas milage with a 400. if you get 10mpg your doing good. these motors just dont get good milage. you can get good HP out of them though. if you want both you should of went with a EFI 460. i talked to a guy who owns a auto shop and he hada 79 Bronco with a EFI 460 that got 19mpg in the city and 22 on the highway. and PLENTY of power. what cam did you put in your motor? i have a Crower RV cam in my 400 and it makes great power. i can break the rear tires lose between 1st and 2nd and i DONT have a shift kit in it. and my truck weigh's about 7000 pounds.
what Carb?
All,
I've found that a quick upgrade from the Motorcraft 2 barrel is the Holley 2300 series two-barrel. If you need more top end put a few spacers in. If it dies off the light pull some spacers out.
Buy a holley book and you can do just about anything you want with it.
KingFisher
KingFisher
what Carb?
I second the holley 2bbl vote. I swapped out my stock motorcraft for a 2300 series holley and have never looked back. Can't say its made a dramatic mpg difference, but just smooth reliable power. Feels like it woke up a few ponies along the way.
If the 4bbl is something you must have, Definatley go for the edelbrock style carb, just for ease of tuning, maintenence, etc. And keeping with your quest for mpg, vaccume 2nds.
Have fun!
Have fun!
hedgeapple
09-11-2015 06:56 PM
jonathan_butler
08-26-2007 07:50 PM
