UOA Castrol GTX 10w30 in 5.4L
Thought I had already posted it, but guess not. It's kind of dated but may be useful to some. Doesn't look like the GTX will do a 5,000 mile OCI under these conditions.
2000 Ford F150 w/5.4L, auto trans, tow package. Driven 6 mi one-way to work (apx 15 min run time) in ambient temp of 40 deg winter a.m.'s, 60 deg winter p.m's, 70 deg summer a.m.'s, 80-90 deg summer p.m.'s. First oil change at 2,000 mi. All subsequent changes at apx 5,000 with GTX at American Fast Lube. (Changed "early" this time as I am now towing a 3000# boat on the weekends as much as I can.)
Miles on unit 31,137. Miles on oil 3,782. Time on oil 5 months. No make-up oil. Castrol GTX 10w30 from bulk. Warner (Champion Labs) oil filter. Air filter (Warner - ? on mfgr) replaced at apx 15,000 miles and this change.
Test done by Blackstone on 7-11-03.
ALUMINUM 5
CHROMIUM 1
IRON 19
COPPER 9
LEAD 0
TIN 0
MOLYBDENUM 43
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 4
SILICON 9
SODIUM 2
CALCIUM 1695
MAGNESIUM 6
PHOSPHORUS 775
ZINC 966
BARIUM 0
SUS @ 210F 56.6 (mid-20 wgt)
FLASH 410
TBN 1.2
Fuel, AF, H2O & Insols within range.
Blackstone comments: "Nothing too unusual ... all wear read well within the average range for this type engine, which is a very good indication of normal wearing parts ... normal wear after about 4,000 miles on oil ... good oil filtration ... TBN was low ... [TBN] probably started out around 7 ... viscosity was low ... try 4,500 on the oil next time."
My Comments: TBN indicates oil is shot. Leave in for 4,500 miles? No way. 3,000 max with towing this summer. Oil sheared down big time. It started off as a mid-30 weight. Doing an Auto Rx cleaning now before switching to either Chevron Supreme 10w30 or Pennzoil 10w30. After seeing Brian A's Chevron UOA ...
ALUMINUM 5
CHROMIUM 1
IRON 19
COPPER 9
LEAD 0
TIN 0
MOLYBDENUM 43
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 4
SILICON 9
SODIUM 2
CALCIUM 1695
MAGNESIUM 6
PHOSPHORUS 775
ZINC 966
BARIUM 0
FLASH 410
TBN 1.2
Thanks for sharing your results. Even with mild temperatures it looks like short-trip driving has really taken a toll on that motor oil. 15 minutes is not long enough to get the oil temperature up to normal and evaporate moisture. Your TBN number tells that story pretty well. A 3000 mile severe service schedule is in order.
I'm surprised that the viscosity is that low. 10W-30 does not need the amount of polymers that 5W-30 needs and Castrol makes a big deal about shear stability in GTX adverts.
Jim
Jim
