Lifter on Cam Help fast please!
The cam lobes are offset and also the bottom of the lifter is convex. The reason for this is to promote lubrication and even wear between the lifter and lobe. The lifter picks up oil on the bottom of it. As the lobe turns with the camshaft it makes the lifter turn so the contact point is always changing. If the lifter was squared up with the lobe it would wear a groove in the bottom of the lifter. This, in turn, would create wear and valve timing issues.
I suppose I should ask to make sure you don't have roller lifters, do you? You can not interchange mechanical and roller lifters on the same cam shaft.
Firemudder
04-13-2007 12:48 PM
Huntersbo
09-24-2005 07:28 PM
