Lifter on Cam Help fast please!
Old 09-10-2003, 10:24 PM
Zaratul's Avatar
Zaratul
Zaratul is offline
I just put the heads on my engine and was putting in the lifters when i noticed that the lifters are not centered on the cam **** deals.
Please reply quickly!!
Old 09-11-2003, 12:23 AM
Superdave's Avatar
Superdave
Superdave is offline
Its fine.
Thats how they are.
Old 09-11-2003, 12:33 AM
Zaratul's Avatar
Zaratul
Zaratul is offline
I guess, if thats the way it sapose to be, but it still dont look any better...
Old 09-11-2003, 08:57 AM
georgedavila's Avatar
georgedavila
georgedavila is offline
That offset is what spins the lifter to avoid wear.
Old 09-11-2003, 09:30 AM
neverenough's Avatar
neverenough
neverenough is offline
The cam lobes are offset and also the bottom of the lifter is convex. The reason for this is to promote lubrication and even wear between the lifter and lobe. The lifter picks up oil on the bottom of it. As the lobe turns with the camshaft it makes the lifter turn so the contact point is always changing. If the lifter was squared up with the lobe it would wear a groove in the bottom of the lifter. This, in turn, would create wear and valve timing issues.
I suppose I should ask to make sure you don't have roller lifters, do you? You can not interchange mechanical and roller lifters on the same cam shaft.
Old 09-12-2003, 12:52 AM
Zaratul's Avatar
Zaratul
Zaratul is offline
I dont belive they are roller lifters and I didn't order any of the parts they were all order from the machine shop that did my block prep work, so I would assume they are all the right things and they look like they would work
17fordguy
10-31-2007 10:31 PM
ErnieX
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
05-02-2007 01:08 PM
ErnieX
05-02-2007 01:06 PM
Firemudder
04-13-2007 12:48 PM
Huntersbo
09-24-2005 07:28 PM
Quick Reply: Lifter on Cam Help fast please!
