serpentine an older 460
Am considering converting my 79' 460 from a v belt to a serpentine system. I understand that 1990 was the first year for the serpentine in a 460. Can I just get the mounting hardware from a 90' and bolt it on? I know I'll have to change the alternator,power steering pump, and the water pump, and add the tensioner. Anybody out there done it already? Thanks
The 460 with the OEM "serpentine" system does not use a reverse rotation water pump. As I mentioned above, the belts run in essentially the same configuration as the old V belts. The alternator / air pump belt gets tensioned by pivoting the alternator. The P/S and A/C belt has a tensioner pulley.
1978crewcab
04-12-2016 12:05 PM
arnoldhunter
04-11-2013 08:28 PM
Sycostang67
04-20-2008 04:50 PM
