1991 XLT Lariat 7.3 Diesel A/T Speedo, Trans Issues
Hello
I just bought a 91 F250 that some one had installed a 92 or newer E4OD into it.
So the trans output shaft doesn't have the gears on it. I've read a thrend how to fix the problem but I'm a little unsure on hooking up the wires to the PCM and the PSOM. Also what wires to disable from the trans current VSS to run a speedo cable. I pick up all the part from wrecking yard I think so hope that part is done.
Thanks for any help
Thanks for any help
mtrosclair
32
03-29-2017 12:00 AM
Cowboydesperado
02-10-2014 08:46 AM
jeff gammon
08-31-2009 12:46 AM
redf1001962
11-13-2006 11:13 PM
