Single click when trying to start
Hello everyone. I am working on getting my 1969 with the 360 back up and running. I changed out the starter for a power master XS this weekend along with the headers to some short tubes. I redid the battery cables. Battery is holding at 12.5 volts. When I start the truck, I get one loud click. I jumped a wire from the battery to the "s" post on the solenoid. The same. One loud click.
I recently rewired the truck, had it running, but redid the gauge cluster and have that unplugged. The points were replaced with a crane cams xr-i ignition. It was running after all this.
Does this point toward a bad starter? Anyplace else I should look? Thanks in advance for any help.
If your jumping 12 volts to the S terminal of the starter relay and getting a loud healthy clunk, I would suspect that the starter is the issue, especially since you just replaced it and it hasn't worked since. Does the clunk sound like it is coming from only the relay or is the starter also clunking?
bman83-mi
03-06-2018 08:19 PM
pdonald
1983 - 2012 Ranger & B-Series
08-17-2005 09:48 AM
69mustang
08-02-2004 03:42 PM
