Hydroboost, Saginaw questions
#31
#32
HOLY BRAKING POWER
got everything buttoned up finally. I had to use a pulley with two belts and had to use the front belt so it wouldn't be so recessed towards the pump and not sit level. Ideally I would like the Lincoln pulley as the one I'm using is off of a GM(IIRC). If I come across it at the junkyard I'll snag it. The hydroboost is AWESOME!! Slight pressure on the pedal and that baby slows the truck down. I want to slam on the brakes to see how fast it'll stop it but I'm afraid everything in the truck will go flying all over the place the Saginaw pump is really handy when sitting still and turning the wheel and it is MUCH quieter. I'm sure it's even better when under serious load having to back up a trailer or something. Overall was it worth it? Yes everyone do the hydroboost upgrade!!!
#34
you know I must admit..I'm not digging the Saginaw pump. I think I might've just gotten a dud or something..it feels the same as the stock pump. At idle and moving...personally i don't think it was worth me going out of my way to get a custom hose made and going through the whole pulley situation. Idk if I'm using the wrong fluid or something? It isn't "one finger can turn the wheel at idle" good. It still takes the same effort as the c2.... now when I first cranked it after installing it WAS "one finger" easy but wasn't ever like that again for some reason...i am running atf should I swItch to just straight power steering fluid? Idk what/if I did something wrong but personally had I known it would've felt the same as the pump I had before I wouldn't have even gone through all that trouble with the bracket, pulley and pressure hose... hopefully it is just something as easy as wrong fluid or something ..
#35
#37
#39
Have you checked the fluid level? It will foam up while bleeding through, then should settle out after a few days, unless you never topped it up, in which case it would foam up every time you use it and work like crap.
The system is self bleeding. You just have to follow the procedure which is something like turn the wheel lock to lock a couple times, press the brake. Turn it off, press the brake to bleed out the reserve. Top it up, and repeat. It WILL be foamy until all the air is bled out (and will take a while for the bubbles to subside ones foamed so it may take a day or so)
#41
Why would you do that? No reason to drive with the cap off, that's a good way to slosh the fluid all over your engine. The cap has an air hole to let the pressure equalize.
#43
so I did this today..finally. It made my brake pedal feel much better to be honest but it actually made my steering more uncomfortable. I didn't lose any fluid in the process. As of now I am regretting the extra time and money I spend to get the Saginaw to work. I am not impressed and the pump I had on prior worked much better. Maybe I just got one made on a Monday morning.. idk. Maybe there's more air?? I did this for almost half an hr
lngroller
12-23-2015 05:35 AM
F-250 restorer
08-02-2013 03:07 AM
Opossum
06-16-2010 04:42 AM
broncoholic
03-01-2005 02:52 PM
