Abs module bleeding question
Okay I have had the brakes system redone except the brake booster it seems to be fine and holding air , but to no help i still have about 4-6 inches of brake pedal travel and when i rapidly press the brakes the Pedal gets rock hard and no brake power and if I'm holding the brakes the red brake light will appear . But I'm thinking it could possible be a abs module ? I had the truck hooked up to a power bleeder and have bleed it at the calipers and wheel cylinders 2x already and it still has not fixed the issue , any ideas would be greatly appreciated
Read this thread and see of anything pops out at you.
https://www.ford-trucks.com/forums/1...-problems.html
