Depressed
Depressed
Hi all,
Well, you'll see in my signature that in June of 2013 I did studs, gaskets, oil cooler heads etc. Went to change the oil and noticed puking...! I'm like, this can't be. I followed everything by the letter. Motorcraft gaskets, MC oil cooler. ARP's torqued to proper specs. I'm not one to hotrod my truck. I do have tunes and they are very mild. Ecno tune, Tow tune and hot tune. I drive in ecno tune 95% of the time and my tow tune pulling my 28' TT.
Kind of depressed cause I'm quite picky on how I do things. Auto/AP mechanic for 35 years. Trying to figure out what went wrong.
Going to do a driving pressure test next week.
When I did the repair truck had 122K on it. Now it has 200K on it.
Wondering if the Motorcraft gaskets has just failed? Felpro'so were not not at the time.
If this holds true that HG'so are blown. Also. I did replace the cap with a new 16 psi cap when repaired.
Thanks for any input.
Eddy
Eddy
I was asking about the cooler, not the valve. Sometimes, depending on the type of delete, an "EGR delete" can fail (welded freeze plugs come to mind). Hopefully not head gaskets!
Easiest thing to do for measuring degas pressure is to tee a gauge into the hose (radiator to degas bottle). You don't have to even cut the OEM hose - just add it at the end.
How did you do that?
You could have a degas cap that needs to be replaced again
Replaced cap today with non click type. Stant 10238. Did it again.
Producing 24-26lbs of boost.
Turbo cleaned, new unison ring 2 years ago. Turbo has been flawless since then.
You could also do the simple test, not sure how accurate it is but it makes sense to me.
Warm the truck up completely, then release all the pressure in the cooling system. Run it and see if all that pressure comes back and how fast.
I am afraid you may be looking at HG again. "What went wrong?" I would really like to know that too. I believe you did everything by the book, and being a mechnic and this is your truck I bet you were very meticulous.
Unless someone can explain otherwise it is my therory that heads lift then the gaskets fail.
Depressing for sure. 10+ yrs and we still don't have this problem licked.
HG's were blown between 2&3, 6&7. Heads were sent to a known 6.0 shop. Magna-fluxed, pressure tested and check for flatness. Heads were not cracked anywhere. Milled and didn't clean up till .008. Which I heard was max that should be taken off.
I'll be running a pressure test this week to see what my pressures are now.
In the mean time I'll do the run it till its warm. Release pressure and see has fast it builds up pressure again.
Thx for all the replies and idea's
Won't comment about a dog?
I hear ya. That one flew right over my head......I got a good laugh out of it.
I might just send the truck to Anthony @SDS next fall of 2018 for a total make over. Planning on keeping her for a long, long time. Truck is paid for and I won't be buying a new one. Took me a year to find this truck.
