1970 f-250 exhaust
1970 f-250 exhaust
I am looking at upgrading the exhaust on my 1970 f250 Camper Special truck. It has two tanks on it which I've heard is a problem when switching to dual exhaust, but was wondering if anyone has done it. I plan on getting a new exhaust manifold and complete dual exhaust/muffler/glass packs. Any suggestions on what to get guys? Thanks
edit: just the exhaust headers would possibly be replaced, I'd rather just link up to what I got....
For dual exhaust, most will opt to run a crossover tube from the driver side, under the bell, to the passenger side and then the tubing parallel to frame.
Alternatively, merge the tubes into a single 3-inch system and a single muffler.
3/4-length headers (like Sanderson PN FF427 headers) are easier to install than long tubes... and they don't trap the starter. Plus it the FF427 is of high quality.
The following users liked this post:
That's the beauty of the Sandersons... ya don't have to unbolt and jack up the engine to install em.
Well, I have a tank just behind the seat as well as under the box on the driver's side door. That's good to know about Sandersons.... seem pretty affordable too.
https://www.summitracing.com/parts/s...27-p/overview/
https://www.summitracing.com/parts/s...a/instructions
Is this what we are talking about? Sounds like if I run it along passenger side I should be able to get it to work true dual exhaust... thanks guys
True... it's all about sizing.... 2.5-inch true duals is the typical max for these trucks... if merging, then 2.5s into a single 3-inch is perfectly acceptable.
Jumpin in here, I have a 70 f100 360 true dual stock manifold and aux tank that runs long paralell to driver side frame rail with a rock guard cover. The pipe crosses to the outside of the frame behind the the steering runs inside the fenderwell over the axel and out behind the tire. I bought it that way. I don't think it's 2 1/2 and the pipe narrows at the bends. Not ready to replace yet...
