03 Fx4 ....clunk after stop, as I release brake an take off from a light. Lube issue?
if it is backlash this would be the first time i have heard about it in a f150 rear axle. im not saying that it is not possible because no truck will have the same maintenance done nor same driver. but i know it is common on the older jeeps with either the dana 35 or chrysler 8.25 on those it is called the chrysler clunk and is normal.
if you have grease and some time there is no harm in pulling the rear drive shaft and putting grease on the out put shaft of the trans where the drive shaft slips on. if it keeps making the same clunk what you can do is check the axle pinion and see if it has any slop in it sometimes the preload on older more high mileage axles get loose and you may be able to tighten the pinion nut just a little and i stress just a little and that may take out some of the clunk if it is still there are you grease the output shaft of the trans where the drive shaft slips on
knightrider955
1999 to 2016 Super Duty
27
09-26-2018 06:12 PM
DevilTruck
08-06-2004 07:14 PM
