Unusual "No-Start"
Unusual "No-Start"
I jumped in my van after service today, and when I turned the key, there was a very brief noise, almost like a small backfire. I'm talking like split second.
It started, stumbled and died.
When I tried to restart, the van acted like a carbed motor with no fire to the plugs. just turned over without firing.
I popped the hood to look things over, and everything look OK. A couple of folks asked if I need a jump, but when they heard it turn over, they were a bit puzzled as well.
I tried giving it a little pump on the accelerator pedal, even though I've always believed that was bad for a fuel injected motor. I tried to start it then and it almost sounded like it wanted to start for a brief moment.
I took another look under the hood and nothing seemed out of place or missing. No smell of gas, nothing.
I tried once more, held the pedal to the floor and it acted like a carbed motor again, hesitated a moment and fired up like the bowls were filled and it was getting gas...ran fine all the way home.
I shut it down, and tried to start it and it fired right up like normal...
Anyway, does anybody have thoughta as to what may have caused this?
Thanks
Thanks
I'm kinda leaning to the fuel system as well...just not sure where in it though.
When it was colder this winter, i would hear a metallic clank on start up from time to time, that seemed to come from down around the fuel pump.
I'm gong to consult my Chilton manual and see if there's a relay down there associated with it.
When it did this the first time, did you start it then immediately hit the go pedal when it fired off ? If you did, that caused the problem. You cannot do this with the newer EFI Fords, you have to let the computer go through it's cycles before giving it the gas. I learned this the hard way with my 06 Mustang GT. I did it then sat there trying to restart it repeatedly. After running the battery down, then jumping it, the only way it did start was by holding the gas pedal down on the floor. Cranking it over and over again loads the cylinders up with fuel, flooding it. Holding the pedal down allowed the fuel air mix to be corrected to allow it to start.
Just saw you post tonite BADDAD.
I didn't have my foor on the pedal when I initially started it.
But when it died I ended up starting it like I would a carbed motor with a sticky choke...
It was strange...I hope to have the new parts in it tomorrow...then will wait an see it they were the culprit.
I do think it was/is the fuel pump.
Oh, got it.
No. I just turn the key and let it do warm up a few minutes.
This time it was almost instant that it shut down.
I tried it a couple more times with out it firing.
Then I gave it a pump on the peddle and tried it and it acted like it want to go.
Thants when I put the pedal to the floore and cranked a few moments and it started up.
Oh, got it.
