Cup holder Suggestions
Old 02-14-2017, 12:02 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
This is what I'm working with. Anything better exist? I'll do fiberglass work if needed, but would prefer something premade
Thx
Old 02-14-2017, 01:49 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,182 Likes on 1,854 Posts
What if you cut the bottom out so the cup would sit in the hole lower?
If you did not want anything to drip inside use fiberglass to fix the bottom back on just lower.
Dave - - - -
Old 02-15-2017, 10:03 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Glue some pieces of PVC plastic plumbing pipe to provide some walls kinda like a drinking glass.
Old 02-16-2017, 11:22 AM
Mookie's 85's Avatar
Mookie's 85
Mookie's 85 is offline
Thx
Last year I picked up a Clutter Catcher at a yard sale for $15 and adapted it to fit my truck. I'm really happy with it. You can still find them new online.
Old 02-16-2017, 11:48 AM
flyguy84's Avatar
flyguy84
flyguy84 is offline
Just bought an 84 and looks like the old man who owned it just before me just screwed these little basket cupholders straight into the dash with two screws on each. I don't know how he did it without cracking the dash but he did it somehow
Old 02-17-2017, 05:29 AM
Lightning23's Avatar
Lightning23
Lightning23 is offline
I am considering something like this on the drivers side. The only other option I was thinking about could use 2 small pieces of 2.5" schedule 10 (just a guess on the size pipe) pipe and fabricate a cup holder. Then bolt it directly to the bottom frame rail of the seat. It would be out of the shifter's reach at that point.
Old 02-17-2017, 07:35 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Thx for input guys
im likely to go 2 routes
1. Hole saw the bottom of current holders out, use pvc pipe to deepen/extend and then fiberglass it all back together
2. Do a quasi centurion hack. Basically cut a nice piece of maple/oak to same shape and mount to top of that current indent. It would add depth, and be easiest
can even cover in grey vinyl to keep color scheme
Old 02-17-2017, 07:38 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Sadly I can't do a full console because my shifter would hit
Old 02-17-2017, 07:54 AM
Cg willie Willie's Avatar
Cg willie Willie
Cg willie Willie is offline
Ive been looking into either making or buying something for a cup holder (love to drink coffee while driving) I found this on Ebay 1999-2004 FORD F250 F350 F450 CENTER DASH CUPHOLDER GRAY OEM SEE PHOTO | eBay
I don't know the mounting dementions but im thinking it might fit where the ash tray goes
If any one has a 99-2001 f 250 maybe you could post the dementions for us
Old 02-17-2017, 08:13 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
I did something very similar in my wife's old Honda Passport.
A leftover piece of 3" stainless trimmed from my Magnaflow tailpipe and some 1 x 1/8 strap fit into the recess of the console.
Drilled two holes where the mounting bolts held down the surround for the parking brake.
Worked great for that same DD cup Tylus has. pictured in the first post.
Old 04-16-2017, 04:22 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Nice outside finally, so I fabbed this up real quick. Made a cardboard template, cut 1x8 to shape, then used some grey stain from one of my wife's projects. Not too shabby
Went from 2" of depth to 3". Seems to work great, will see what the big bounces do
Here are 2 cans, same hieght.
Old 04-16-2017, 06:05 PM
grumpin's Avatar
grumpin
grumpin is offline
Good job! I have a cup holder, the one that hangs from the door over the front of the console with some velcro to hold it in place for now. I like your idea.
Old 04-16-2017, 07:54 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
At some point I'll get a proper hole saw and pretty it up with nicer wood
But for now it works. Need to get my suspension dialed in, and rust repaired before I spent a lot of time in the cab
Old 04-16-2017, 08:43 PM
reamer's Avatar
reamer
reamer is offline
You have to remember the D.D. cup was designed Waaaaay after the cup holder was designed.....
Old 04-16-2017, 08:44 PM
reamer's Avatar
reamer
reamer is offline
Now we need something for us with Lariat bench seat, Standard and 4x4
Quick Reply: Cup holder Suggestions
